Boring a 5.3L to 4"
Although it seems highly unlikely that it will last. I mean 6.0 iron blocks max out around 0.070 bore and some brave souls have taken them out 0.125 to do iron 7 liters.
Now you're asking a similar build block to go almost twice the absolute max and three times what most people dare do.
Can it be done? Yes. This is after sonic checking EVERYTHING and ensuring nothing is even the slightest off or out of round. Even then, everything left is paper thin. Literally.
There's pics floating around somewhere where someone did it and you can actually SEE the grooves in the liners when it was complete (aluminum block, however)
Once you factor in all the cost for machining and sonic checking, you're over the price of a regular 6 liter block either used or from summit / Jegs.
Sell the 5.3 and get a 6.0. Saves you some money as well.
