Ls6 intake worth the $
Old Jun 9, 2014 | 02:16 AM
Goodkat's Avatar
Default Ls6 intake worth the $
Looking to swap out my Ls1 intake for the Ls6 my question is for the gain in HP is it worth the cost. So far all im seeing is the normal ebay garbage 350-500$ ie I hate the auction crap haha, so is it worth it or should I go another route?
Old Jun 9, 2014 | 06:27 AM
ramairetransam's Avatar
yes its worth it , dont spend more than 350 shipped for one.
Old Jun 9, 2014 | 08:00 AM
Rise of the Phoenix's Avatar
I also agree that it's worth it. Comb the classified section on here for one.
Old Jun 9, 2014 | 10:14 AM
1994_383_Z28's Avatar
Definitely worth it. I'll be selling one soon that I'll let go for $350 shipped to your door.
Old Jun 9, 2014 | 02:46 PM
c7monster's Avatar
They're worth it. The fast's are also worth the money
Old Jun 9, 2014 | 09:44 PM
JRENIGAR's Avatar
Id spend $350-400 for an LS6 intake that should easily net 10-20 hp long before Id spend it on a catback that might net 5 hp.
Old Jun 10, 2014 | 03:51 AM
Goodkat's Avatar
Thanks for all the replies now is there anything more I would need to know before purchasing. Is it a straight swap or would I need anything extra to along with it? ie fuel rails, tb anything like that I should know about?
Old Jun 10, 2014 | 04:00 AM
Goodkat's Avatar
1994 383 z28 I am interested if you could send some pics that would be awesome
Old Jun 10, 2014 | 07:39 AM
Blackpanther99's Avatar
Sure is....
Old Jun 10, 2014 | 09:21 AM
BlueBird346's Avatar
You will need to clearance the bottom of the intake to clear the coolant lines. Other than that, it's pretty straight forward iirc.
Old Jun 10, 2014 | 09:44 AM
SilverWs6-98's Avatar
Remember when installing the intake to look out for the oil pressure sensor. It's located at the driver side rear end at the very back of the engine. From my research it is common to break these. I just recently installed my FAST 90 on an broke mine off at the base. Easy fix just had to take off the intake again to do it.
Old Jun 10, 2014 | 06:19 PM
Goodkat's Avatar
That's a drag you broke it off just more work to do, but thanks for the warning I will be sure to watch for it. By shaving off do you mean all the crossed plastic lines on the bottom?
Old Jun 10, 2014 | 09:06 PM
Yea that's right. You can use a hammer and a chisel or flathead screwdriver. Don't have to remove all of them though, just the ones in the way.
Old Jun 10, 2014 | 09:32 PM
peakesshou's Avatar
Old Jun 11, 2014 | 12:09 AM
Goodkat's Avatar
Yea but from what iv read the fasts cost around four times what an ls6 would run me.
Old Jun 11, 2014 | 12:13 AM
Goodkat's Avatar
Nice I will probably go with a driemel see how clogged I can get that thing ha before I take out the hammer and chisel. Thanks Bluebird
Old Jun 12, 2014 | 11:57 AM
paradigmGT's Avatar
I am also interested in buying an LS6 for my 1999 Camaro SS.
Other than the actual intake manifold, what other parts are needed for the swap? How much to expect to pay for these additional parts?
Do you require a tune after installing the LS6?
Old Jun 12, 2014 | 10:20 PM
WSTEXAS's Avatar
You need to change your coolant lines to the ls6 front coolant lines and rear block off plugs no tune is required after installation other then removing the egr if you don't have it then it's no problem
Old Jun 12, 2014 | 10:28 PM
You don't have to. It's recommended not to if you can avoid it. Just clearance the ribs on the bottom and keep the stock lines.
I kept my LS1 lines unto I switched to a FAST.
Old Jun 13, 2014 | 12:05 AM
Goodkat's Avatar
Thanks again BlueBird still trying to find one for a decent price.
