Flow #'s for AS 5.3's
Old May 18, 2004 | 07:30 PM
Orange Juice's Avatar
Default Flow #'s for AS 5.3's
First I want to thank Jay for working with me and putting together the package that I was looking for.
Lift Intake Exhaust
200 144 117
300 202 158
400 255 196
450 276 207
500 293 213
550 306 222
600 313 226
I will be running the Comp 224/581/114 cam with the CompR lifters and Yella Terra rockers. I added an adjustable timing set,a ATI super dampner, ported intake and a 78mm tb. I already have the TPIS headers Y pipe and RT cats.
Old May 18, 2004 | 09:20 PM
destroyerSS's Avatar
are they stage 2 or 2.5's? bet ya can't wait to bolt those bad boys on
Old May 19, 2004 | 03:50 AM
These are the Stage 2's. Yeah I just can't wait to see what this combo will do. Jay was pretty optomistic about the numbers since this will be running through an m6 and stock 10 bolt for now. I do more autox and lapping then I drag so I've left the stock 10 bolt in for now.
Old May 19, 2004 | 06:22 AM
Ben01C5's Avatar
The flow numbers look good. Hope it puts out what you want.
Old May 19, 2004 | 07:48 AM
offaxis's Avatar
Congrats on the heads.
If you run those compR liftrs make sure they are shimmed correctly with the right push rod length or you can make low numbers. I wouldnt put them into my car unless there was a pro doing the work that has experience with them. I am sure its a simple thing to do but I see alot of problems out there and my friend just had a roller brake off his comp R and destroy his cam and probly more. IT only took about 100 or so miles to collapse and break a part.
Old May 19, 2004 | 07:58 AM
Ryan04Silverado's Avatar
Relax now, Comp R's have been performing well with few failures. Lets not get everyone worried about their lifters because of a few problems. Every part in your car has the opportunity to fail.
Old May 19, 2004 | 09:18 AM
PREDATOR-Z's Avatar
Why comp "R"?
Why not Crane replacement lifters.
Old May 19, 2004 | 09:38 AM
Crowley's Avatar
Lift Intake Exhaust
200 144 117
300 202 158
400 255 196
450 276 207
500 293 213
550 306 222
600 313 226
Great numbers ... now If I can only get mine
Crowley
Old May 19, 2004 | 10:33 AM
offaxis's Avatar
Ryan
Im saying they have to be setup correctly to prevent that. Not everyone put the right shims and even comp tell you right on there site that "you have to run an adjustable rocker with these lifters". Set up with the correct geometry im sure they are great.
Old May 19, 2004 | 06:35 PM
Brian2001SS's Avatar
Numbers look great. I know I love mine
Old May 19, 2004 | 10:45 PM
Country Boy's Avatar
Senior Member
I love mine too. I put down some good numbers for a Florida car
