Oil Pump Question...
Old Jun 30, 2014 | 10:04 PM
SoonerBrad88's Avatar
Default Oil Pump Question...
So I'm piecing together everything to do heads & cam on my car and I've almost bought an oil pump but figured I would double check on here before doing it. I'm wondering if the pump in my car will work. I run Mobil 1 5w30, and when the car is warm at idle it will hold 40 psi. Usually gets up to around 60 at wot. It only ever drops below 40 when its extremely hot out and I'm stuck in traffic. Does anyone have any thoughts as to if I should go ahead and replace it or do you think this one I've got is sufficient?
Old Jul 1, 2014 | 05:47 AM
LS1-450's Avatar
Put a new spring in it & it's good.
Old Jul 2, 2014 | 02:45 PM
duffman_1's Avatar
^agreed. Also, take a peak at the relief piston and the bore. If it's scored then replace, but if it looks good put in a new spring and go!
Old Jul 2, 2014 | 05:27 PM
Where can you find the springs? And are there different springs?
