GM MLS gasket?
Old Jul 5, 2014 | 02:33 PM
TXZ28LS1's Avatar
Default GM MLS gasket?
In the middle of installing my livernois motorsports ls6 heads. The mls gasket part number they gave me is #12589227. It has 6.0L stamped on it. Will this work?
Can i install the gasket as is or do i need to spray them with anything.
Old Jul 5, 2014 | 03:13 PM
TXZ28LS1's Avatar
Anybody know if ill be fine with these gaskets? Im wondering if they are meant for bigger bore or if they will be fine for my 00 ls1..
Old Jul 5, 2014 | 04:07 PM
KCS's Avatar
KCS
Moderator
It's common practice to open up the chamber to 4", so they probably did intend for the 6.0L gasket to be used.
Old Jul 5, 2014 | 05:48 PM
RezinTexas's Avatar
just make sure the bore of the chamber is smaller than the bore of the gasket. A light copper spray is sometimes used, won't hurt anything.
Old Jul 5, 2014 | 10:34 PM
.boB's Avatar
Modern MLS gaskets are already coated. They are meant to installed dry.
The gasket bore should be as close to the cylinder bore as possible, without extending into the cylinder. The space between the cylinder wall/piston and the gasket is kind of a dead space. The flame front doesn't light that off very well. The bigger that dead space is, the more air/fuel doen't get lit.
You won't notice any difference in feel, but might lose a pony or two. The exhaust gas will read rich, even though it really isn't. And you might have trouble passing an emissions test.
Old Jul 6, 2014 | 09:16 PM
BADD SS's Avatar
True, and gm mls seal pretty good.. That being said, there is a spray that definately helps cometics....
Old Jul 7, 2014 | 12:15 AM
TXZ28LS1's Avatar
Thaks for all your help guys.. my head n cam install went well.
