Torque sequence for main caps...
Old May 19, 2004 | 10:15 PM
xssive's Avatar
Default Torque sequence for main caps...
Anyone have the torque sequence for the main caps and a picture showing the seqence numbers?
Also, with arp main studs, is it reccomended to torque, undo, and retorque a few times?
Old May 20, 2004 | 12:16 AM
xssive's Avatar
ttt...
Old May 20, 2004 | 08:12 AM
xssive's Avatar
Nobody knows?
Old Mar 22, 2007 | 06:20 PM
Pray's Avatar
Originally Posted by xssive
Nobody knows?
That's what I said.
Old Mar 22, 2007 | 06:27 PM
brad8266's Avatar
Holy **** this thread is old, how the hell did you find this one Pray?
Old Mar 22, 2007 | 06:31 PM
Pray's Avatar
I have been searching for this answer for a week now. I googled the same subject and this page came up on ask so I thought I would freshen it up. There are plenty of people on here assembling engines and I refuse to believe that no one knows the freaking sequence. I am sure there is an on line GM manual some where. I just have to find it. I will be assembling my short block next week so I need to know soon.
Old Mar 22, 2007 | 06:36 PM
brad8266's Avatar
http://www.gmhightechperformance.com.../photo_48.html
Torque inners, then outers, then the side bolts seems to be the sequence.
Old Mar 22, 2007 | 08:56 PM
Pray's Avatar
Do you think it matters where you start. I know there was a sequence to the old motors. Plus in that article they say to follow GM's sequence but not their specs.
Old Mar 22, 2007 | 08:59 PM
brad8266's Avatar
Im know the main caps are engraved with numbers, that may be the sequence, Im not 100% sure though.
Old Mar 22, 2007 | 10:15 PM
braap's Avatar
If you have powerpoint, I've got a diagram that I could email you.
Old Mar 22, 2007 | 10:24 PM
brad8266's Avatar
Email it to brado8266@yahoo.com
Old Mar 23, 2007 | 12:31 AM
playtoy's Avatar
I have been told by a couple of builders that you need to line hone the mains when switching the main cap fasteners. I'm not sure if you are doing a final assembly or what, just thought that I would share that with you.
Damn this thread is old. 2004?
Old Mar 23, 2007 | 06:14 AM
brad8266's Avatar
Here is the torque sequence courtesy of braap, he emailed this in powerpoint and I just put it in word. This is how I would have done it had i not had a diagram anyway. I always torque most thing from the inside out.
File Type: doc
Old Nov 27, 2007 | 10:12 AM
N4cer's Avatar
So do you cross up? Like instead of going 12345678910 would you go 12435687910? Basically saying do the first torque of each cap on the same side, or first torque on opposite sides.
