Need help on cam I bought.
Hello, I recently ordered a cam with specs:
Advanced Duration: 273/277
Duration@ .050: 224/228 114LSA
Valve Lift: .581/.588
It's going in a built 5.3l with a 3200 stall and 4.10 rear gears, and I plan to put a 150-200 shot of nitrous on it.. My question is the advanced duration. When I ordered it I didn't know it was advanced. Will this help me or hurt my plans? Or should I just send it back and get a new one? I have no idea about the advanced duration.. Any help is very appreciated.
With a IVC of 42 you should be fine. Now if your want more top end and don't mind sacrificing some low-end power then get a adjustable timing gears set and retard the cam 3-4 degrees(ICL 113-114) This will move you power band up roughly 200-300 rpm.
