Lean at WOT and won't idle.
Old Jul 17, 2014 | 01:41 PM
curbcheck's Avatar
Default Lean at WOT and won't idle.
1995 240sx with an lsx swap and a 228/228 cam, car ran good for a few months, then I developed rod knock. Pulled the motor and rebuilt it with stock in internals. Now sometimes I can get it to idle and sometimes it wont. When I can get it to idle, my wide band reads 14.8 to 15.4. When I Rev it the idle will start surging and it will stall. Finally decided to take it for a spin and it is lacking power at mid throttle, wide band reads about 15.7. When I go WOT wide band doesn't even register. Fuel pump and filter is new. Fuel pressure is good. Vacuum gauge reads about 16 to 18 inches at Idle. Did a compression test and got 155 to 160 on all 8. Oh and it is tuned for the cam. Could my cam be off 1 tooth and still run somewhat? Anybody have any other ideas?
Old Jul 17, 2014 | 02:03 PM
Old Geezer's Avatar
Wrong forum. Tune/diagnostics is the best place to get this kind of help...
Old Jul 17, 2014 | 02:09 PM
curbcheck's Avatar
It's not a tuning issue. Somethings wrong with the motor.
Old Jul 17, 2014 | 08:54 PM
curbcheck's Avatar
Just finished putting the motor back together. Timing chain was installed correctly. I'm going to clean the maf ckeck again for vac leaks and recheck fuel pressure tomorrow. I don't know what else to look for.
