98 ls1 6 speed miss...help
Old Jul 17, 2014 | 11:35 PM
Senetonix's Avatar
Default 98 ls1 6 speed miss...help
I've changed all I plugs and swapped around wires and coils. Misses at partial and wot but only sometimes...throws a cylinder 1 misfire code. Sometimes the cel goes off by itself and stays off for an hour to a day or more then comes back. Suggestions?
Old Jul 18, 2014 | 11:03 AM
Always2Slow's Avatar
First thing I would do is take a voltmeter and set it to read OHMS. You need to ohm out all the wires and see if you have a bad one. Do that and then report back.
