Engine build advice
Old Jul 20, 2014 | 02:11 PM
laki187's Avatar
Default Engine build advice
Hello all not new to the LS community or the board (i read here daily) but i was surprised i never registered here. Ive been registered on LS1.com forever. Anyways lets get to it.
I bought a 02 WS6 M6 with 98k on it last march (my 3rd F-body) bone stock from a dealer. Car runs and drives beautifully no issues whatsoever. I had to take a trip to NYC and drove the T/A up there while i had to make a stop in NC at my buddy's place so we could talk mods on the car. Right before xmas there was a huge snow storm here in NYC. I had the car parked with my car cover on it for 2 days till the snow was gone. I dug out the car 2 days later to load it back on the uhaul trailer and this is what it did the second it started. So i pretty much know the answer but what to do you guys think it is?
I know all about the common problems these engines can have with lifters and bent rods etc.. just need some opinions from you all. I immediately got the car to a shop and had the oil drained, no metal in the pan or filter after we cut it open. 7 months later the car is still at the shop untouched cause i wont let them do anything to it. I took the intake off, both valve covers off and everything looks good so far on the top end except lifters since i didnt remove the heads.
By the looks of the cam would you guys say it spun a bearing? Ill get to engine build questions in a bit i just want to see some responses from you all first. Thanks in advance.
Attached Thumbnails Engine build advice-cam-1.jpg   Engine build advice-cam-2.jpg
Old Jul 21, 2014 | 08:24 AM
laki187's Avatar
Nobody has any idea? Any help would be great.
Old Jul 21, 2014 | 08:48 AM
svede1212's Avatar
Sounds like a lifter more than bearing
Old Jul 21, 2014 | 09:26 AM
.boB's Avatar
Looking at the cam lobes won't give you info at all about the bearings.
It sounds like a valve train noise. Rod knock is a deeper tone. Could be something simple like a collapsed lifter. Or it could be a broken valve spring.
Old Jul 21, 2014 | 09:31 AM
laki187's Avatar
That's actually good news for me. I was thinking spun bearing. Gotta pull heads when I have some time.
