Oil for high mileage ls1
Joe Gibbs oil is very good-and can be had for the same or less cost than most other synthetic oils. When my stock of German Castrol runs out (they no longer make it) I'm going Gibbs. Royal Purple is good-but certainly no better then other oils for much less money and not worth it IMO.
And NO, never put an additive in your oil. Lubricant engineers work long and hard to perfect their oils, don't go and ruin it with any other junk. And that Lucas stabilizer? Just 90 weight oil with paraffin (soap) in it and it's been shown to foam up the oil. Foamed oil is AIR-which you don't want as a lubricant.
BTW, never use Fram oil filters.
I started using a lot of oil, like 1 qt every 1000 miles. It also started pinging at light throttle. So I knew it was carboned up but I figure the rings might be pasted with carbon too causing the oil usage. I ran a bottle of techron through and it helped the pinging but not the oil usage.
So I decided to try a product called Rislone in with the oil. It dissolves carbon and the oil filter picks it up. All the lifter noise is gone and it stopped using oil.........
Guys using oil with 75k plus miles on stock engines might want to try it. I'm going to use it every oil change for a few. Good Luck grasshoppers.
The vast majority of Fram filters are so poorly made that none of them can be trusted. I don't care that the Ultra is their "better" filter-for your 8 bucks you can get a better filter.
If you had $8 for an oil filter, the Mobil1 or Wix/CarQuest is certainly a better choice than a Fram Ultra.
- Viscosity is how thick the oil is, like 5W-30 or 14W-50. The higher the number, the thicker the oil.
- The first number - 5W, 10W - is the thicknes of the oil when cold. Lower is better. That way you get good oil movement when the engine is first started.
- The second number - 30, 40, 50 - is how thick the oil is when hot. Higher is not better, contrary to popular belief. You need enough viscosity to maintain proper oil pressure in all situations, and no more. Thicker oil takes more energy to move around, and puts added wear on some engine components. That, in turn decreases efficiency.
I use a 5W-30 in my race/street car. Works great, good UOA's, and minimal bearing wear.
Synthetic vs. dino is also a popular discussion point. Synthetic has two advantages: heat management and extended drain intervals.
- Oil is heated primarily by rpm's. If you're road racing, oil can get pretty hot. Otherwise, oil temps are rarely an issue.
- An extended drain interval is nice if you drive your car a lot. 12-15K miles between changes is pretty common. If you drive that many miles a year, it might be more convenient for you to change it once a year. BUT.... if you only drive 5-6K miles, you still need to change it once a year. Might as well use the cheaper dino oil; same results, half the money.
- A true synthetic is just that - synthetic. They use a PAO base stock - Man made, in a lab, by chemists. No dead dinos involved. There are only 4 true synthetics on the market: Royal Purple, Redline, Amsoil, and Schaffer. Mobile 1, castrol syntec, etc, are NOT true synthetics.
- These semi-synthetics start with dead dinos, and are then refined to a point where the FTC allows them to be called "synthetic". That doesn't mean they're a bad oil. For most vehicles on the road, they are just fine. But they're priced like a synthetic, and that (IMO) makes them a bad value.
- Based on UOA's, the semi-synthetics do not hold up as well as a true synthetic.
I use Royal Purple. It's easy to buy in almost any Wal-Mart, cheaper than M1 from Autozone, and the UOA's show that it performs better and lasts longer.
Looking at the additive packages for the major synthetic oils you won't see a ton of difference. Your driving habits and frequency of oil changes will make a larger difference than a slightly different additive package. Mobil 1/Champion/Bosch, Napa Gold/Wix/Dana, Puralator Pure One, K&N, and Baldwin 251/253 all make decent filters. A lot of them are the same filter with just a different name stamped on them. You can do a little research to find the micron/filter rating to ensure you get what you need. Most important thing is to change it. Oils oxidize just sitting in your dirty oil sump. The dinos can get waxy just sitting on the shelf in cold weather. I would change dino oil more than once per year if your miles are >5K. BJ's sells the Shell synthetic for $4/qt and I use that in my daily driver - change it twice per year. The additive package is not all that different from Pennzoil Platinum. Boron, Sodium, Moly, and Magnesium are the main additives that seem to differ between brands. I have no idea if the extra Sodium in Royal Purple works better than the additional Boron, Mg, and Moly in Mobil 1.
http://pqiamerica.com/March2013PCMO/...sallfinal.html
Read this and you'll understand why you want the 5W cold weight and not a 10W. The 0W may even be better offering less cold start wear. Probably not a huge difference between the 5W-30 or 5W-40. I'd use the 5W-30 that GM recommends for the SS. The same weight synthetic oil flows better at low temps than the same weight dino (ie 5W-30 syntec vs. a 5W-30 dino)....hence less engine wear. 90% of normal engine wear occurs on the cold start (even 100F is "cold").
http://www.bobistheoilguy.com/motor-oil-103/
Joe Gibbs, Redline, Royal Purple and Amsoil are VERY expensive-$10~$14 per quart, even when bought in gallons or pails. Deals can ONLY be found on Royal Purple. Of the four of them, I think I'd go for the Redline first.
Edit
Just to note I do not specifically run Fram filters. I buy whatever Synthetic oil
And filter is on sale. Mobil 1, Valvoline syn, Penz Plat, and what filter is on special...K&N, Bosch distance...etc. The bottom line is change your oil and filter regularly and you will be fine.
5 quarts of Amsoil 10W-40/1 quart Amsoil Z-Rod 10w-30 and an Ea064 filter in the SS. Car sits a lot especially in the winter, which is why the Z-rod is in there. Changed once per year. Usually early May.
6 quarts of Amsoil XL 5W-30 and an Ea011 filter in my 2002 Expedition changed twice per year. Usually end of April end of October.
You don't need anything special for an LS engine unless it is some kind of custom build, in which case use what your builder recommends. The main thing is you want plenty of Zinc, but as mentioned above do not us additives. I don't like Mobil-1 because the valvetrain makes to much noise when not warmed up. From what I have read it is a bit lower on zinc and lower on the scale for 10w-30. But GTX has never let me down for my bolt on F-bodies.
