dynamic compression help
Old Jul 29, 2014 | 10:31 PM
SStressin's Avatar
Default dynamic compression help
so im trying to figure out my dynamic compression ratio. my numbers on the cam card is all in .050. is there a conversion to get it to advertised so i can use the calculator? if anyone can help me its a ls1 383. 11.2 to 1 static, cam specs are 240/256 .647/.647 111lsa. im at sea level. also ABDC is 48 at .050. i came up with 9.94 to 1 with using that which i know is wrong.
Old Jul 30, 2014 | 05:33 AM
RezinTexas's Avatar
there is no conversion that will be accurate for every cam. You need to know the numbers at 0.006" valve lift for your specific grind, contact the manufacturer.
Old Jul 31, 2014 | 01:42 AM
99Bluz28's Avatar
This is only a rough guess since the duration @ .006" valve lift aren't known.
DCR 8.19, if the ramp rate of the lobes are 55
and...
DCR 8.38, if the ramp rate of the lobes are 50
So your DCR is roughly any where from 8.19 - 8.38 .
Old Jul 31, 2014 | 05:22 PM
JakeFusion's Avatar
Super Hulk Smash
I'd say it is the 8.3:1 range. The cam is probably around a 50 degrees ramp from .006 to .050 and is installed on a 108 ICL per the ABDC @ .050.
Old Jul 31, 2014 | 09:31 PM
Always2Slow's Avatar
Bottom line is if you wanted more static you have room to add more.
