Wiring gear selector switch
Old Jul 30, 2014 | 08:17 PM
Slonomo99's Avatar
Default Wiring gear selector switch
I have a floor shifter out of a 2005 trailblazer that I put in my s10 with a 5.3 and a 95 4l60 tranny the shift input shaft is to short to put the new style nuetral safety switch on it. On the shifter I have it has the safety switch and gear selector switch built into it. I had the wiring harness built but they left out the wires for the gear switch I was wondering if someone could help me with what wire goes where on the PCM? Thanks in advanced
Old Jul 31, 2014 | 08:31 PM
LS1MCSS's Avatar
Is that 95 tranny a PWM transmission? If not, you may have problems getting it to work right. You don't have to have the switch on the tranny for a swap to work.
Old Aug 1, 2014 | 09:33 PM
Slonomo99's Avatar
Yes it is a pwm tranny some reason it's stuck in limp mode it's getting 12v to the transmission I was thinking maybe it's because the computer doesn't know what gear it's in? Do you have any suggestions?
Old Aug 1, 2014 | 10:08 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Certainly NOT internal engine related.
This belongs in the automatic transmission section over here: https://ls1tech.com/forums/automatic-transmission-13/
