Does the block need to be deck for a head swap?
Old Jul 31, 2014 | 02:43 AM
LS325ci's Avatar
Default Does the block need to be deck for a head swap?
Im a bit confused on this. I have done a few head gasket swap and have always had to clean the gasket off pretty much to bare metal(I have only worked on iron blocks)
at one shop i work they used a small circle air (die?) sander and sanded it. Made me cringe(thinking of uneven surface) but it worked(and was fast method).
when I work on turbo engines they have to be machined.
so why is it on ls1 the only tools used to clean the block surface is a plastic ice scrapper?
I was looking at ls1howto.com
is it b/c its aluminum that you can leave some of the old graphite on?(not going to bare metal according to the DIY)
seems like it would blow a HG if not cleaned all the way.
is that really all it takes for the ls1?
I may do the heads first if it is.
Old Jul 31, 2014 | 04:07 AM
Always2Slow's Avatar
Many people recommend the plastic ice scrapper because the aluminum is soft and can be damaged if other methods are used or cause waves if not done properly with a cookie disc.
Old Jul 31, 2014 | 06:14 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Scotch-Bright does a great job and doesn't disturb the surface.
Old Jul 31, 2014 | 09:59 AM
redbird555's Avatar
What paul said... I usually go to the auto parts store and get permatex gasket remover in a can and it literally melts the rubber stuff of the surface then I use a plastic scraper or metal razor blade and VERY lightly finish cleaning it up. Done 3 head swap and never had an issue
Old Jul 31, 2014 | 11:38 AM
LS325ci's Avatar
This is what we used at the shop one time. What do you think? I feel like this would have better control than that.
Old Jul 31, 2014 | 11:41 AM
Paul Bell's Avatar
Sure, that'll work too but I always suggest tools assuming the user doesn't have air or air tools. Either way works.
Old Jul 31, 2014 | 11:43 AM
LS325ci's Avatar
I have done this my first time around and did not work on a turbo engine. (head was machined) I guess with n/a it's more forgiving.
