LS1 windage trays
Old May 21, 2004 | 05:40 AM
GTS346's Avatar
Default LS1 windage trays
I just purchased a LS1 truck oil pan for a conversion, it has a built in baffle in the pan although I have seen other trcuk pans with windage trays.
Would there be any difference between the 2 performance wise? Does the windage tray make any difference?
What do corvettes/camaro's etc have windage or baffles?
Old May 21, 2004 | 04:38 PM
WILWAXU's Avatar
The car LS1's have a "windage" tray...
We'll see if the guys in internal engine can help you out
Old May 21, 2004 | 04:42 PM
GREGGO's Avatar
Moderator
The trucks use the baffle AND the windage tray.
Old May 21, 2004 | 05:06 PM
GTS346's Avatar
So if I use the truck pan in a car conversion can I get away with just the baffle or do I need the tray as well?
Old May 21, 2004 | 05:10 PM
Sniper33's Avatar
and its the same dimensions as the stock LS1 tray on our cars??
Old May 21, 2004 | 08:00 PM
GREGGO's Avatar
Moderator
I would use both since that is the way truck engines are designed. Couldn't tell you if the truck and LS1 is the same, but I would expect they are. Obvoiusly the truck pick up tube is needed since it's longer.
Old May 21, 2004 | 08:09 PM
P Mack's Avatar
On my car, the windage tray was bolted to the block, not the oil pan. The oil pan did have a baffle bolted to it though.
Old May 22, 2004 | 06:08 AM
GTS346's Avatar
So all LS1 engines come with windage tray bolted to block?
