Longer pushrods?
Old May 21, 2004 | 01:02 PM
HAMRHEAD's Avatar
Default Longer pushrods?
I installed some yella terra rockers and with or with out the shims the pushrod can still spin when the rocker is tightened to 22 ft/lbs. It is tight but it will still spin some with the index finger. This is only on a couple pairs though. The rest are fine. Do I need longer pushrods or am I just stupid and doing something wrong?
If it matters I have a 224/228 112 cam, PP stage II LS6 heads, and new comp 850 lifters.
Why won't **** just go together right
Old May 21, 2004 | 01:06 PM
Nasty N8's Avatar
You may have the lifters compressed if they are brand new they have never been pumped up. And are you checking them on TDC?
Nate
Old May 21, 2004 | 01:12 PM
HAMRHEAD's Avatar
No I had a small problem with checking them on TDC. Once the heads were on my buddy who was helping me turned the engine over and I don't have enough experience in being able to tell where TDC is anymore. I soaked the lifters in oil for 36 hours. Not sure what else to do. Why is it only some rockers? Do I need to turn the engine over a couple of times and try to re tighten them?
