which 1 of 2 cams should i keep?
Old Aug 6, 2014 | 10:39 AM
Joe Lluvia Avila's Avatar
Default which 1 of 2 cams should i keep?
custom grind 231/239 .617/.623 @ 112 LSA or keep my current cam which is an off the shelf comp cam 285LR-HR13 (235/243 .621/.624 @ 113LSA). The custom grind was meant for another setup but the guy wants my cam and wants to do a trade.
89 fox body. EFI 2003 5.3 with 2001 silverado PCM, stock 706 heads, PRC dual .650 springs, 7.4 chromoly pushrods, comp cam 285LR-HR13 (235/243 .621/.624 @ 113LSA), 36# injectors, walbro 255, fuel reg. set to 60psi, 4l60e built with red clutches, "beast" sunshell, larger belt, corvette servo, hd2 shift kit, circle d single disk 2500-2800 stall (does NOT stall past 1650rpm), stock trac-loc 8.8 rear with 3.55s, 27x8 hoosier slicks (beat to hell). thru the floor subframes, boxed stock control arms, stock suspension.
