help identifying this crank
Old Aug 7, 2014 | 01:20 PM
youngster99's Avatar
Default help identifying this crank
Ok so I've done a lot of reading on which crankshaft from an lq4 will bolt to a T56 6spd. I know I need a 2001 or newer. But this crankshaft is not stock I don't think. The 2 numbers I see on the crank are 066 and 12552215. Can anyone help me identify this? I have a Tranzilla 6spd in the car. I'm trying to bolt up to. Thanks in advance!
Old Aug 7, 2014 | 02:52 PM
Hamrdown's Avatar
it took a whole 3 seconds to find your answer. There's plenty of threads on this here in tech as well.
Old Aug 9, 2014 | 12:27 AM
LLLosingit's Avatar
All of the ’99 – ’00 cranks had the 12552215 casting with the wide flange. This is the only application for a crank that has a 92mm stroke and a wide flange.
