Floating 4.8 (6.276") Rod??
Old Aug 10, 2014 | 10:24 AM
Bilster's Avatar
Default Floating 4.8 (6.276") Rod??
Did GM ever make a floating pin rod for the 4.8? My motor combination calls for a 6.276" rod but I need a floating pin.
Old Aug 10, 2014 | 10:35 AM
KCS's Avatar
KCS
Moderator
Why do you need a floating pin?
Old Aug 10, 2014 | 05:19 PM
Bilster's Avatar
I'm using JE forged pistons with a floating pin. Do I get my 4.8s bushed? On the average....what does that usually cost?
Old Aug 10, 2014 | 05:34 PM
KCS's Avatar
KCS
Moderator
You can use a pressed pin on it, it doesn't make any difference to the piston. Now, that is unless the piston requires a .927" pin, then you need an aftermarket rod since the stock rods all use a .943" pin.
Old Aug 11, 2014 | 03:39 PM
1FastBrick's Avatar
GM Did make floating pin 4.8L rods
They would be found in a 2005-UP 4.8L application's
Old Aug 12, 2014 | 01:30 PM
Bilster's Avatar
Yup...thanks, FastBrick. I was browsing through the Parts Classified section and found a set. Thanks for verifying.
