Factory rocker arm bearings
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I would do it even if you had a stock cam with any real mileage on the vehicle. Is it necessary? No. Not unless you're already loosing needle bearings. But it's designed to be preventative maintenance so that you do not have issues in the future.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
I'd make sure to look over all the rocker bearing and end caps very carefully, the end cap have a tendency to work there way out over time.
I did my trunion upgrade myself with a small $60 arbor press, but a good bench vise will do fine. Just take you time and the install should be flaw free.
