shimmed installation
Old Aug 25, 2014 | 06:05 PM
mullahi's Avatar
Post shimmed installation
hi i have 243 heads for 6.0, 99 camaro i would like to know more about the shimming installation i have issue of how to install them can someone please explain to me how to install them or at least post a link for me talks about this problem?
Old Aug 26, 2014 | 06:17 PM
Mercier's Avatar
Shimming what exactly? Rocker arms? Valve springs? Stock 243s should bolt right on to a 6.0 or LS1 with factory-type head gaskets.
Old Aug 26, 2014 | 08:45 PM
99Bluz28's Avatar
The valve springs will typically need to be shimmed (under the seats) if the installed/seat height is higher than recommended, or if you're wanting to shim the valve springs to within .05" of coil bind at max lift.
Old Aug 27, 2014 | 06:30 AM
vettenuts's Avatar
Under the seat for the standard umbrella seal, over the seat for the one piece seat/seal used in later motors.
