Intermitten hard start
Old Aug 25, 2014 | 07:27 PM
Transambrandon's Avatar
Default Intermitten hard start
The cars a 2000 camaro z28 ls1 auto 82k miles
Mods: ls6 intake, lt headers, exhaust and a tune. Egr and AIR deleted
For the past couple months I have had a very rare occurrence where my car doesn't run well the first time I turn it over. Il turn it, it will start, idle rough around 300 rpms. Then it either bogs out or I shut it off. Most of the time I can start it fine the second turn. This happens very rarely and starts the first turn 99% of the time. Today was different though, every time I turned the car off and let it sit , I'd have the same symptoms : bogging and hard start. I checked fuel pressure, it's 60 while running and 50 when I turn the key to the on position. It would slowly go down over time. I sprayed maf cleaner around the engine to see if there's a vacuum leak. I couldn't detect a leak. Any ideas guys?
Old Aug 25, 2014 | 10:25 PM
LLLosingit's Avatar
Does the fuel pressure continue to drop with the key off or is it holding pressure? I had a similar problem from leaky injectors would make my truck hard to start if it sat for a few hours or overnight, 3 of 8 were leaking. It would run ruff and bog when first trying to drive away but then clear up and run fine.
Old Aug 25, 2014 | 10:40 PM
Mercier's Avatar
Same on mine(early 5.3 truck motor) but fuel pump mostly. I first suspected injectors. It showed pressure but wouldn't keep it there all the time apparently... only when I wasn't looking. Would run FINE for hour or more and get iffy when it felt like it. Got almost totally better and then I changed the fuel pressure regulator... which older models have. Does yours have the vacuum-referenced regulator?
Old Oct 20, 2014 | 02:52 PM
Just to add a conclusion to my problem. The PO replaced the alternator. When I started looking into the problem I found a loose bolt on the alternator. I tightened that up and made sure the battery was hooked up good. After that , the problem has disappeared. I'm guessing the fuel pump was getting enough power or something wasn't grounded maybe.... Idk but I'm glad it starts right up!
