Looking to build a nice street motor.
Old Aug 27, 2014 | 02:31 PM
bluebommer07's Avatar
Default Looking to build a nice street motor.
Ok right now I have a stock iron lq4 I'm considering building a 402 with some 243 heads 90mm and some long tubes. This would be going in a 97 sierra reg. cab. what type of cam would yall suggest for my goal if possible shooting for something in the high 400hp to low 500 hp range if possible n/a. I'm open to all suggestions
Old Aug 27, 2014 | 02:56 PM
doc350's Avatar
I'm currently doing something similar to you, but its an LS1 in an 02 RCSB Silvy. When I was looking at cams, I focused more on low to midrange power rather than a peak number. If this is a street driven truck, you will spend most of your time below 4500rpms. Something to think about as you look for a cam.
The advantage you have is the extra displacement will give you the low end torque you want.
Old Aug 27, 2014 | 09:19 PM
xdanny510x's Avatar
Just talk to one of the sponsers and see what they recommend... And ur goals for ur truck...nothin better than talkin to the pros
Old Aug 28, 2014 | 09:24 AM
ss4chad's Avatar
I too am building a new motor for my '03 GMC Sierra SLE. I have the full size (8ft bed) truck with a Circle D 2800 converter in it.
I am building an LS1 383 stroker. 4" stroke crank, 6.125 rods, 3.095 pistons, PRC 1.0 heads, truck intake. I am looking at a cam from PCM of North Carolina;
http://www.pcmofnc.com/index.php/per...9x-050-111-lsa
Made for a heavier vehicle, nice lumpy sound, I like it!
Chad
