tick knock
Old Aug 28, 2014 | 06:47 AM
ifixkars's Avatar
Default tick knock
I have a 02 Camaro ls1 stock that has rebuilt short block it has a hard tick noist and low oil pressure with hot engine at idle I took off drivers valve cover to see if I could find anything wrong didn't see anything so I started motor with cover off I seen oil spraying up from cylinder 3 exaust rocker and the rest of rockers barly had oil coming out of push rods any ideas on why this woud be?
Old Aug 28, 2014 | 11:08 AM
BlwnLs1GTO's Avatar
Pull off the springs and replace the valve stem seal.
But that doesn't account for the Tick sound...
Any hard driving before this happened? Over revved or anything like that?
also,
Low oil pressure needs to be addressed immediately. Or you will have much more problems very soon.
Old Aug 28, 2014 | 01:46 PM
ifixkars's Avatar
valve seals are new and have not over reved at all just 55 miles of light driving noise don't get worse just stays the same and I have 40 lbs of oil pressure with throttle slightly pressed
Old Aug 28, 2014 | 07:50 PM
LS1-450's Avatar
Run it for 4 or 5 min & see if tick goes away. It takes 1.5-2 minutes before all rockers get oil from lifters.
Old Aug 28, 2014 | 08:03 PM
ifixkars's Avatar
I ran for 15 minutes so i decided to pull head and look at lifters and found 2 callapsed so i put all 8 in bank 1 will finish putting together tomorrow and post results
