Explain what Lsa with +2 means.
Old Sep 1, 2014 | 07:21 PM
VandykeT/A's Avatar
Default Explain what Lsa with +2 means.
I've tried searching this but can't find a clear answer. What does this mean. Can the cam still be installed dot to dot. What exactly does this change vs a cam just on a 112. Thanks
Old Sep 1, 2014 | 07:27 PM
BlueBird346's Avatar
112+2 means it has 2 degrees of advance ground in to the cam. Also means it has a 110 intake centerline. 112+0 means no advance and a 112 intake centerline.
Old Sep 1, 2014 | 07:43 PM
VandykeT/A's Avatar
So I can install dot to dot correct?
Old Sep 1, 2014 | 07:58 PM
treybadd's Avatar
Theoretically you can install dot to dot. If you don't know how to figure out the meaning of 112*+2... Then trying to degree a cam may be a bit too much to tackle. I would dare to guess that 95% of all cam changes are done dot to dot with no checking.
Old Sep 1, 2014 | 08:01 PM
HCI2000SS's Avatar
I always like to verify the ICL since grinds can vary depending on the manufacturer
