help me build a 6.0
Old Sep 9, 2014 | 10:02 PM
355c10's Avatar
Default help me build a 6.0
So I've done a little research and personal opinions on what I should build. Ultimately it's up to me. But I want to get some feedback and more advice
Will be going into an 86 c10.
Parts list I've come up with -
6.0 Block.
Or used afr or trickflow 225s(what other heads can I use)
Brian tooley valvesprings
Bullet cam or Brian tooley custom grind
Super Victor intake
950 carb
Induction solutions kit and plate. Msd 6sl box
Shoenfeld swap headers
I want something in the 600 range or close to it. Want to try and keep my th350.
I also have 373 gears BNIB I can install.
Would anyone change anything? All help is appreciated
Old Sep 10, 2014 | 12:45 AM
Mercier's Avatar
Wheels or crank HP?
Old Sep 10, 2014 | 01:40 AM
CAMSTER's Avatar
Do anything you want and get a bottle of nitro lol...
If can run at list 11.25 compression and willing to zero in on the cam, can rather easy ball park 600 crank hp assuming a detail type.
Using small bore ls7 heads / ls7 intake will be my choice.
600 tire hp is a bit more complication for a 6.0 two valve single cam v8 "assuming" street engine.
