Old Sep 10, 2014 | 05:00 PM
sbf's Avatar
sbf
Default 416
Hi guys thinking about a new engine.im thinking about a ls3 stroker 416.
Heads-tea ls6 243 brand new
Intake-fast 92 ported by tea
Btr lifters
Ported ls6 oil pump.
I have seen 416 with stock ls6 heads and intake pat g cam make 480rwhp thru auto.
Also 416 ai ls6 heads make same power unlocked stall with valve float.
I'm keeping my heads and intake I no there are better heads out there but I have and gonna keep them.with 11.7 cr and pat g cam I feel like I can make at least 500rwhp.its going in a 71 nova street/strip mostly street 4l60e circle d 5c stall.hoping to run 6.50-6.30 on motor 3300lbs.also will I need a vacuum pump.do you guys think my goal is unreal
Old Sep 10, 2014 | 05:16 PM
Russ K's Avatar
I reused my TFS 215 heads on my 418, and unshrouded the valves to match the .040 Cometic head gasket (11.5 CR). EPS supplied the 234/242/.600/.615 117+2 camshaft that drives 10x better than the 234/242/.600/.610 114 cam that I put up for a year.
The new cam has 4* overlap vs 10* of the old cam, still has stupid bottom end power and has more mid range to top end power due to the earlier exhaust valve opening.
I have BTR Platinum springs with Ti retainers and Yella Terra Ultra Light rockers.
No dyno numbers, but I'm sure I should be ~525 RWHP in my M6 2001 ZO6.
Russ Kemp
Old Sep 10, 2014 | 05:20 PM
sbf's Avatar
sbf
Thanks Russ.what oil pump and intake do you have
Old Sep 10, 2014 | 06:18 PM
Russ K's Avatar
Stock oil pump, Mamofied 90/90 intake with a Black Wing air filter. LG long tube pro 1.75" headers, high flow cats, 3" exhaust with LG 3" mufflers & over axle pipes.
Russ Kemp
Old Sep 12, 2014 | 06:48 PM
sbf's Avatar
sbf
Anyone else
Old Sep 24, 2014 | 03:26 PM
SStheBest's Avatar
I have a 418 going in soon and i have TEA's Stage2 job on my 243's and im using their PAC dual springs
FAST 90
LS2 TB
EPS 240/248 .624 .6XX 116
LG's 1 3/4
Halltech stinger
I should be around 500rw when its up and running. Still deployed.
Old Sep 25, 2014 | 06:29 PM
sbf's Avatar
sbf
I've been thinking about selling my fast 92 and go with a super vic,accufab throttle body
