need Help
Old Sep 16, 2014 | 12:57 AM
h2oh2o2o2014's Avatar
Default need Help
I just put together my 402 an went too start. The motor an no spark so I took the mad out an had it tested an it came back good I'm thinking the crank sensor is bad any help I no nothing about pc
Old Sep 17, 2014 | 11:34 AM
Mercier's Avatar
Please clarify.. "mad?"
Old Sep 18, 2014 | 09:03 PM
crainholio's Avatar
That was a tough post to translate into English, but here's a go at it.
I'd whip out the volt meter and probe one injector connector on each bank for 12VDC with the ignition in RUN position. Only 2 pins and one must have 12VDC to ground.
If no 12VDC, time to check the INJ 1 and INJ 2 fuses. The injectors and coils for each bank are supplied 12VDC by these two fuses.
If yes, I'd then get a $5 noid light and see if the injectors are pulsing during cranking.
