ls1 locked up
Old Sep 16, 2014 | 11:14 AM
twistedbowtie's Avatar
Default ls1 locked up
I just picked up a 2001 ss camaro i got a really good deal on this car the guy told me tye motor is locked up it is missing all accessories, intake , throttle body and has been sitting this way so I know the motor has been opened I'm not sure where to start on this. Should I go head and pull the motor and tear it down and see what needs tobe replaced or what should I do? I have not had a chance to mess with it at all I having even tried to turn the motor over.
Thanks dustyn again I got this car really cheap
Old Sep 16, 2014 | 11:59 AM
Taspeed's Avatar
sounds like the cam isn't degree'd in right. make sure your at tdc on a compression stroke.
Old Sep 16, 2014 | 12:53 PM
Okay. Would the cam randomly jump timing ? Or would the previous owner had to of done it?
Old Sep 16, 2014 | 01:01 PM
I really don't think the guy did a cam swap the crank pulley is still on the motor it looms more lime he was parting the car out.
thanks
Old Sep 16, 2014 | 01:26 PM
gagliano7's Avatar
Take all the spark plugs out and see if you can turn motor over by hand.
