Engine Main Cap installed backwards... what do I do?
Old Oct 2, 2014 | 04:34 PM
Kacuziken's Avatar
I would replace it myself. Think about how much money you already have invested in it as it sits, Then add in the time to put the motor in and pull it back out and any repairs that may be needed if there is a problem.
The cost of a new bearing sounds pretty cheap to me.
New King bearings are ordered! Thanks for the advise!
Old Oct 3, 2014 | 08:20 AM
MuhThugga's Avatar
Make sure that numbskull installed the oil galley plugs in the front and rear of the block.
A guy I know had a machine shop assemble a shortblock block for him and they forgot to install the rear plug.
Old Oct 14, 2014 | 07:06 PM
Kacuziken's Avatar
Originally Posted by Paul Bell
Replace the bearing with new and cross your fingers.
If this were my engine, I'd pull ALL the bearings to have a look.
Pulled all the bearings saw two others that didn't look so great! Replaced those! Then figured I would check the ring gaps while I had it out! So you guessed it ... they weren't what Total Seal said to put them at! Top and second ring (Bore X .0065) so 4.03 x .0065 = .026. He had the top ring at .022 and second at .020. Or something like that! Looks like I will be filling some rings too! Fun Times!
Old Oct 16, 2014 | 04:31 PM
spent21's Avatar
I. would. be. pissed.
Old Oct 16, 2014 | 04:47 PM
scotty2000ss's Avatar
Lawsuit?
Old Oct 16, 2014 | 07:02 PM
Kacuziken's Avatar
Pissed doesn't begin to describe what I am feeling! But we live and we learn and I will get this straight and will have rebuilt the whole engine myself!
Old Oct 16, 2014 | 07:05 PM
Kacuziken's Avatar
Originally Posted by scotty2000ss
Lawsuit?
I honestly don't even want to deal with him anymore in any capacity! Yeah I lost money but luckily I found the errors before I finished the motor! hopefully this will be it and I can push forward!
Old Oct 17, 2014 | 08:28 AM
MuhThugga's Avatar
Sounds like he didn't file the rings and just slapped everything together. It also sounds like he reused bearings. You may want to inspect the cam bearings as best you can.
Well, you wouldn't have been able to finish the motor anyways because the rear cover would have never installed with the cap on backwards, but yes, it is good that you caught it now instead of later and had to disassemble other ****.
Old Oct 17, 2014 | 08:51 AM
Maybe at least report that place to the better business bureau. I hate the fact that someone else could ha en the same thing happen.
Old Oct 17, 2014 | 01:30 PM
Kacuziken's Avatar
I provided all the parts for the build. I checked the bearings when I pulled them out they were the bearings I provided also! I did look at the cam bearings before installing the cam. Everything looked ok! Cam is alittle tight but it's within spec.
He certainly filed them some because they were cut in a V. "Not straight". But we will get that taken care of!
Old Oct 18, 2014 | 10:35 AM
svede1212's Avatar
Definitely sounds like he has no idea what he is doing. The second ring should have a wider gap than the top ring. FWIW I put my Dremel in a vice with a disk in it and pushed the sides of the rings in on it to make a parallel gap and it worked really well.
Old Oct 18, 2014 | 08:41 PM
  #32
Kacuziken's Avatar
Thanks Svede! I will definitely use your Dremel idea!
Old Oct 19, 2014 | 10:36 AM
  #33
ckpitt55's Avatar
Another option, albeit a more expensive one if you already own a dremel. Relatively inexpensive as far as ring grinders go though and worked great for me
http://www.powerhouseproducts.com/ph...ide-wheelhtml/
agreed on second ring needing to be gapped larger than the first. The inverse would trap gas under the top ring and cause sealing / flutter problems.
Make sure you deburr them after you get them cut to size!!!
Old Oct 20, 2014 | 09:32 AM
  #34
MuhThugga's Avatar
At least he used the stuff you provided.
It wouldn't be the first time that someone provided parts to a builder, and the builder used whatever he had laying around and kept the new stuff for himself.
