Engine Main Cap installed backwards... what do I do?
Old Sep 30, 2014 | 03:43 PM
Kacuziken's Avatar
Default Engine Main Cap installed backwards... what do I do?
I need some advice on my engine. I had a guy build my motor and he installed the rear main cap on backwards. So i pulled the cap to turn it around and it looks like there is some wear on the bearing. Could anyone tell me if this will be ok or do i need to put in new bearings.
Old Sep 30, 2014 | 03:52 PM
KCS's Avatar
KCS
Moderator
That's probably ok, but I'd be more worried about how well he actually built it if he couldn't even install the caps on correctly.
Old Sep 30, 2014 | 04:20 PM
Kacuziken's Avatar
Yeah I'm pretty worried about that to!
Old Sep 30, 2014 | 04:45 PM
96capricemgr's Avatar
Was it machined atall?
Old Sep 30, 2014 | 04:58 PM
Kacuziken's Avatar
The block was bored and honed. New cam bearings installed. I bought all the parts and had him install them. Stock crank, king bearings, scat rods, D.S.S Pistons and total seal rings.
Old Sep 30, 2014 | 05:21 PM
i was wondering if it could have been line honed with the cap backwards.
was the engine run or just turned over by hand?
Old Sep 30, 2014 | 05:22 PM
Kacuziken's Avatar
Just turned over by hand
Old Sep 30, 2014 | 08:24 PM
Kacuziken's Avatar
So should this be ok to use or should I replace the bearing?? Any advice would be helpful!
Old Sep 30, 2014 | 08:51 PM
LLLosingit's Avatar
I would replace it myself. Think about how much money you already have invested in it as it sits, Then add in the time to put the motor in and pull it back out and any repairs that may be needed if there is a problem.
The cost of a new bearing sounds pretty cheap to me.
Old Sep 30, 2014 | 09:16 PM
RockinWs6's Avatar
If it was align bored with the cap backwards<very hard to believe anyone could be that stupid> then you need to start over. If you pull everything back apart you will be able to put the caps in alone and look if they line up.
Old Oct 1, 2014 | 09:37 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Replace the bearing with new and cross your fingers.
If this were my engine, I'd pull ALL the bearings to have a look.
Old Oct 1, 2014 | 12:04 PM
MuhThugga's Avatar
Is that assembly lube or engine oil that was used?
Old Oct 1, 2014 | 01:48 PM
ckpitt55's Avatar
I'd be more interested in what the clearances / bore shape / bearing crush is if you had it line honed.
More often than not, a line hone does more damage than good.
Old Oct 1, 2014 | 06:30 PM
jmargo's Avatar
Why not take it back to the guy that built it ?
Old Oct 1, 2014 | 11:22 PM
LLLosingit's Avatar
hmmm.... Maybe because he installed the main cap on backwards in the first place?
Old Oct 2, 2014 | 08:18 AM
KCS's Avatar
KCS
Moderator
That depends on the machinist.
Old Oct 2, 2014 | 08:57 AM
RockinWs6's Avatar
Looking close at that picture you can see that bearing is badly damaged.
Old Oct 2, 2014 | 10:40 AM
jmargo's Avatar
There was still money exchanged (I assume). You don't reward incompetence by fixing the problem yourself. If there is doubt in his ability then the whole motor should be taken apart and checked for clearances, correct bearing orientation and such.
Old Oct 2, 2014 | 11:02 AM
KCS's Avatar
KCS
Moderator
Looking at the parting faces of the caps, it doesn't look like the caps were cut.
Old Oct 2, 2014 | 04:32 PM
Kacuziken's Avatar
I will not be taking it back to this guy again. I will fix it myself! Not rewarding his incompetence just learning from this and moving forward with the build.
