Aggressive cam lobes?
IMO if youre going to twist the motor up/want to leave it together for awhile Kips line of thinking....yep.
Good friend of mine who runs a cam motion SFT has had it in since I was a kid still runs hard today nice to see you guys are still around.
There is no need in having 8 different lobe styles or variations for the LS Chevy hydraulic cams. Most of the engine combinations I see on here run from idle to 6500 RPM with a valve lift from .550” to .650” lift and with spring seat pressure 130lbs to155lbs with 350lbs to 400lbs open pressure. The measurable differences in these lobes are very slight, the real difference is that some of them operate very well and others do not. The “hard” or “aggressive” lobes may make a small amount more vacuum at idle and may show a two pound gain in torque at 4000RPM but will cause more valve noise and float the valves sooner plus having a destructive affect on valve train parts and valve seat sealing. The “softer” lobes will have a little less vacuum at idle but provide quite valve train operation and extend the valve “float” RPM 300-500 RPM and do not destroy valve train components.
What do you call “aggressive? Is it high acceleration or high velocity? Which is harder on the valve train? The cam with higher lifter acceleration rates will be harder on the valve train.
Let us compare technical data on two lobes both with 230 degrees duration at .050” with .350” lobe lift. One lobe we’ll call “hard” the other “soft” even though I don’t like to use the word “soft”, but it is soft compared to the hard lobe. I prefer to call it the correct lobe for your engine.
Compare:
HARD SOFT
MAX ACCELERATION: .00037 .000323
MAX VELOCITY: .0073 .00775
NOSE ACCELERATION: .00023 .000212
So which one is more “aggressive”? The soft one moves the valve FASTER or higher speed. So what is aggressive? One of the reasons the hard lobe floats the valve sooner is because it has higher “nose” acceleration, which is negative acceleration at the top of the lobe.
Kip.....thanks for taking the time.
I have a few questions for you, if you will. And please excuse my limited knowledge and any questions that seem elementary.....
-Is this a blanket statement for "Cam Motions" line of hydro cams (would you spec the same seat intensity for a "max effort" {1.8+per cube} LS as a cam only setup ) ??
-Do you believe in the theory of power under the "area" of the curve (when stability is controlled) ??
-Do you believe 0.006" - 0.020" intensity should be a function of the specific induction and exhaust system (differential pressure, reversion, limited fill..etc)??
-Do you believe that ramp rates influence the "time" it takes the hydro lifter to go "solid" (because technically the seat duration, IVO, is not what is printed on the cam card, its the point where the lifter goes "solid") ??
-So wouldn't preload effect "true" IVO...and when coupled with different seat intensities your presented with an array of variables when talking hydro cams...... ?? (since we are splitting hairs...lol)
I've always been of the mindset.....lift the valve as quick as possible without sacrificing stability, zero loft and set it down as soft as possible.
But I guess it all depends on what it is you are trying to achieve.
I don't believe there is a perfect cam profile.
If there was, we would all be using it by now.~per Warpspeed
Thanks again Kip
Most of the time I would. Here is why. We had to re design and re grind 50 BBC cams that were made by another company. These 50 cams were made for a stationary engine that turned 1800 rpms
so this company designed the lobe and ground the cams. They were so volant they beat the hell out of the valve seats turing only 1800 rpms.
We redesigned the lobes reground the cams ( they were new cams BTW)
Now they have been running for the last three years. Guess who designed the cams?
I do not understand this question
Did you mean .006 to .200?
The lifters are solid when they are pumped but the valve does not open at .001 cam lift it may not open until .010 cam lift or .030 at high rpms. What you have is deflection.
-So wouldn't preload effect "true" IVO...and when coupled with different seat intensities your presented with an array of variables when talking hydro cams...... ?? (since we are splitting hairs…lol)
Almost same as above.
You are correct on the statement but you are limited to what you can do.
Thanks again Kip
Would love to see what you would come up with for a cam for my build. Kinda wanting a 60mm core thats gun drilled as im going for high rpm.
Your saying the opening and closing ramps (seat - 0.006") are what you hold as a "standard". But beyond the 0.006" you will get as "aggressive" as the build/valve train demands ??
I understand your seat - 0.006" stance, if you lose control of the valve train early in the cycle it makes it that much more difficult to control. We have all seen those crazy spintron videos.
-Does Cam Motion believe in the lift curve has a correlation to the flow curve and crank angle/cylinder depression (thus, power under the curve) ??
-Does Cam Motion agree with this example of an average hydro 0.630" cam ??
.000-.100 68 degs 22%
.100-.200 40 degs 13%
.200-.300 26 degs 8.5%
.300-.400 34 degs 11%
.400-.500 32 degs 10.5%
.500-.600 60 degs 20%
.600 + 44 degs 14.5%
And when cleaned up a little looks like this.
35% of it's time below .200"
30% of it's time between .200-.500"
35% of it's time between .500-.630"
~per D.M.
-If a costumer is running a competitors camshaft with one of the more "aggressive" hydro lobes on the market (LSK) and has zero float or loft at 7500rpm (per the dyno graph), does the Cam Motion "softer" lobe make more power in the usable rpm range (5000 - 7500). Using the same 0.050" events ??
-Does Cam Motion believe that there is always power on the table...up to the point of valve train chaos ??
Aggressive.....as in, taking more spring, lighter valve train parts or a combination of the two...to control at the rpm the induction systems wants.
Thanks Kip for your time.
Russ Kemp
~per D.M.
Lets put it this way I get aggressive after .05 with high velocity/lifter speed. lobes that has a low .006 get aggressive before .05 which is noisy and harder on the lifters.
That is mostly caused by truing to get to much duration @ the .200 number with higher negative acceleration at the nose.
~per D.M.
You can out trick yourself with all these numbers. You always want the valve to be open as much as the application will allow for the intended use.
It could go rather way. Just because something is big it does not mean it’s better.
Sure but you have to find it.
Most people over spring just like most people want a cam that is to big for there application.
