Drive with bent rods OK?
Old May 24, 2004 | 10:00 PM
rambo benson's Avatar
Question Drive with bent rods OK?
Anyone drive for a while with ticking sound/bent rods and had no problems? Horror stories?
Over seas right now, but missed a shift in the SS. Ticking sound but car runs OK. When I get back I'm going to need to immediatly drive everyday, then figure out heads/cam or what. It's that or a rental!
Compression test needed I know...when I get time.
Thanks,
Ram
Old May 24, 2004 | 10:05 PM
mooleyz28's Avatar
No u can drive on them... I drove mine to the dealer and ripped on it the whole way trying to put one through the block to get a new engine... NEVER DID but i still got a new motor... Knew some friends are the dealership... Just drive nice... and if u throw a SES light... be very weary of driving it. Ill say get it fixed ASAP... the install is about 2 hours if u never did it before. Open her up right after work... check them out... replace and bam your good to go... But its up to u...
Hope i helped.
Old May 24, 2004 | 11:53 PM
pbjones81's Avatar
if youre car isnt under warranty i wouldnt recommend driving it hard as mooley did for obvious reasons. but like he also mentioned, driving it easy shouldnt hurt anything.
Hope i helped.
Old May 25, 2004 | 09:07 AM
Keenov's Avatar
I bent mine awhile back at the track. Got on it going home and it went fine.. Hehehe..
Though when I took them out.. They were shaped like an "L" I am sure that they would have soon broke something. Get them replaced ASAP.. That sound is annoying anyways!!!
Old May 25, 2004 | 10:53 AM
CamTom12's Avatar
So if I've got an annoying ticking coming from what sounds like the headers (not the exhuast leak ticking, but something you can hear against buildings and walls that I drive past.), we're probably talking bent pushrods? Are there better or harder pushrods I could use when I finally do my Cam swap?
Old May 25, 2004 | 11:00 AM
mooleyz28's Avatar
Ya when u do your cam swap get a kit... the kit will come with either hardened or chrome-moly pushrods, comp valve springs, and a cam swap gasket. Thunder Racing has a nice package for 700. Just do that... U wont regret it. Goodluck man.
Old May 25, 2004 | 11:02 AM
Tom@SpeedInc's Avatar
dunno if harder pushrods are better, if they don't bend something else like a valve will. One attribute of the pushrod engine. Valves and pistions hitting on a interfearance OHC motor.....oooo it is nasty. profilable for the mechanic though
Old May 25, 2004 | 11:03 AM
CamTom12's Avatar
Thanks!
Unfortunatley due to some circumstances, this summer's cam project is being pushed off into the future some time... I'll definately keep that in mind for when I do the cam, though. I've been talking to Al Futral and I think he's got a similar package.
Old May 25, 2004 | 12:55 PM
Thanks!
I'm still looking at making this an excuse for heads or h/c! I just need to find a great shop in St. Louis to do the install quickly.
RAM
