dynamic compression ratio for ls2
Old Oct 22, 2014 | 10:29 AM
jakews6's Avatar
Default dynamic compression ratio for ls2
need someone to help with calculating the dcr of a factory ls2 with a cam using comps 13018 intake and 13019 for the exhsust lsl lobes on a 112+4. I can't seem to get it right. Thanks in advance. 231 dur 617 lift and 235 ,621
Old Oct 24, 2014 | 07:57 PM
svede1212's Avatar
You need the advertised duration (@.006 lift)
Old Oct 24, 2014 | 10:00 PM
squalor's Avatar
I came up with 8.29 DCR
Duration at 0.006 for 13018 is 281 and 13019 is 285. LS2 is 4" bore and 243 head is 64.5 cc chamber. Did I get it right ?
This was using the PianoProdigy calculator. It only seems to like advance center line and does not seem to recognize a retarded centerline, say 228/228 110-1 LSA
