HELP 408 oil pressure
Old Nov 2, 2014 | 12:15 PM
LOstrolencki's Avatar
Default HELP 408 oil pressure
Recent problem with start up pressure. Gauge will not read any pressure for a few seconds then slowly pick up to around 40 lbs. then shift from 30-40 until motor is warm.. Once the motor is warm there is no issue with pressure. Idle at 40 and rise to 60 when accelerating . ???
Old Nov 2, 2014 | 04:23 PM
mark21742's Avatar
Are you sure you don't have anything slightly blocking any of your oil ports? I had oiling issues and ended up finding a small ball of RTV pushed up against the barbell in the back of the motor.
Old Nov 2, 2014 | 04:45 PM
I'll check but it's something that recently started. At the same time it started getting colder and the speedo also stopped working all together
Old Nov 4, 2014 | 06:38 PM
mark21742's Avatar
Ok in that case start by checking the grounds on the back of the drivers side head.
