which set of instructions do i use for ARP head "studs" on LQ4
Im on ARPs website and trying to figure out which set of instructions I should use. Would it be the LS1, LS2, or what. I see one with 90ft lbs for M11 bolts and 28 ft lbs for M8 bolts. I also set a set saying 80ft lbs and 25ft lbs.
If your engine is 2003 and earlier, the kit you should be using is 134-3609.
If your engine is 2004 and later, the kit you should be using is 134-3610.
BOTH kits call for torque ratings of 75 & 25 ft lbs.
I checked the instructions for both those part numbers but it says thats for head bolts. I have head studs, would it be the same or different?
Sorry about that. I just reread my caption for the thread and I did put head bolts. Thats my fault. I just corrected it
With those other part numbers I realized that the instructions are exactly the same so I thought I would compare all the instructions for head studs. SB Chevy LS1 pro-series hex
Head Stud Kit 234-411, SB Chevy LS1 pro-series thru '03 12pt Head Stud Kit 234-4316, andSB Chevy LS1 pro-series '04 12pt Head Stud Kit 234-4317 all have the same instructions and torque values. So I think its safe to say no matter what kit I have I should be good. Sorry for being a dumb *** guys lol. Thanks again for your help
