LS6 any problem running sodium exhaust valves with solid intake valves?
Thanks!
How about stock exhaust and put the savings toward aftermarket hollow intake?
Only the LS6 exhaust valves are sodium filled. The LS6 intake valves are hollow stem valves, NOT sodium filled. Are you certain you got "boned"?
If you do not have the hollow stem intake, I do not see the point of running a sodium exhaust. As Caprice said the Intake valve is always the hardest to control.
GL
Manley Race series? I'm open to any suggestions. This is my first time building a motor with anything but OEM GM Valves.
