350z LQ9 budget build
Old Nov 5, 2014 | 10:43 PM
V8z33's Avatar
Default 350z LQ9 budget build
Im planing a budget lq9 build and was curious if ls9 springs will work on a stock 317 head (stock valve & pushrods) with a 222/224 .566 .568 cam? from what I've searched i see that 317 heads are identical to 243s however the valve height is SLIGHTLY taller on the 243. so i guess I=my question will these work on a stock 317head?
http://www.compcams.com/Company/CC/c...csid=1090&sb=2
http://www.lingenfelter.com/mm5/merc...9#.VFr7uN6FVHg
thanks for the input i will post pics and a build thread soon… gotta get that post count up some kind of way right? lol
Old Nov 6, 2014 | 01:53 AM
bane89's Avatar
Why did you want to change springs?
If your gonna keep the stock cam and not gonna boost you shouldn't need aftermarket springs.
Those springs should fit with no issues. They look like a copy of ls6 springs which are around the same price.
Old Nov 6, 2014 | 09:23 AM
2muchboostNY's Avatar
Paid $50 for the blue (used to be yellow from what people say) springs from GM directly. I would just go to a local dealer and pick up a set for that price.
Old Nov 6, 2014 | 03:52 PM
V8z33's Avatar
I'm using this cam, 222/224 .566 .568 with STOCK HEADS..
Old Nov 6, 2014 | 06:37 PM
bane89's Avatar
I recommend these.... If its in the budget.
http://www.ws6project.com/user_stor/catalog/lsx-beehive-pac-racing-valve-springs/
If not ls6 springs should be ok in the mean time.
