Head Gasket Thickness?
Old Nov 7, 2014 | 11:50 AM
paperboy326's Avatar
Default Head Gasket Thickness?
What does a stock 2004 5.3l (LM7) Silverado have for a head gasket thickness? .051 or .057. ?
Were going to add a a small cam and thinner head gaskets. Going in a CJ so not building a racecar.
If .051 go to .040 gaskets?
Or
If .057 go to .051 gaskets?
Thanks
Old Nov 7, 2014 | 11:53 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
If I remember correctly it should be a .054" thickness. Those motors have a lot of piston to valve clearance so you can run the .040" with no issues.
John J
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
