Newb LQ9 build questions
I'm looking to do an LS Swap in my 72 El Camino I just picked up. Most Likely an LQ9 or LQ4. I'm looking for awesome Low end torque, great drivability. 22+ MPG on the freeway and 400-450 HP to the rear wheels.
I have no drag racing dreams, just having fun and blowing Ripping Panties
I have been looking at building an LQ9 with L92 Heads, LS3 Intake, Cam and (Lifters???), Throttle body and Headers that will fit my Elky. Is this possible with this setup or a couple additions. What would be necessary and can I achieve the the MPG with this? Otherwise I would most likely Build a 383 and supercharge it as it seems a cheaper/Easier route.
It currently has a Rebuilt TH350 with 2500 Stall, 12 Bolt with Posi (unknown gears) and am about to install this week a Hotchkis TVS Suspension and Steering Assembly, AGR Steering Box, New Body Bushings and Wilwwod 6 piston brakes up front to be able to Handle the power and put it to the ground/not kill myself and break everything. I know the TH350 will most likely eventually die and then I'll do a 4L80E but I'd rather brake it first and get some time before shelling out the dough and install time for a transmission and controller.
Is my dream of a great street cruiser/Havefunmobile possible. And if so what parts would you recommend changing or adding and what headers would work with my Elky.
Thanks a million. I know it's a lot of questions
400-450rwhp is a lot more than most have experienced and about as much effectively used on the street, even to drive well at that level you need more stall and to be sure it has at least 3.73 gears.
Why do you want to use heads that really need a bigger bore than you are going to give them? Read a magazine article pointing out peak flow?
Cam it, upgrade the torque converter and get a 4l60e at least in it, get some 3.73-4.10 gears. Could mill the 317s.
Take the money you would have spent on the heads/ intake and call one of the sponsors.. rebuild that LQ9's bottom end. It's what I wish I did. If I could go back, actually, it's the only thing I would have done. I could have done heads, intake, cam, and all that later... but now I have to pull the engine to do it.
