Block crack! New block options
Old Nov 10, 2014 | 06:42 PM
RedDemon_ls's Avatar
Default Block crack! New block options
My car is a ls1 but the block cracked and I'm wondering what block would be good to go with but not outrageous ! I seen the ls1 and ls2 blocks are around the same price! Which would be the best to get out of them 2? And could y'all refer me to a different block or anything that's all I know of? Please help
Old Nov 10, 2014 | 07:19 PM
Fry_'s Avatar
If on a budget a used L33 block can be bored out more or less making it a LS6 block. I'd just buy a short block from TMS if I needed a new block.
Old Nov 11, 2014 | 10:58 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The LS2 is a slightly bigger bore block, but will require you to use a couple extension harness on your ls1. The 5.3 aluminum is also a good choice, but would require block boring as well as a hone.
Sometimes it is cheaper just to buy a new short block complete with high end internals.
Give us a call, we can help you with a block only or an assembled short block. We have the blocks and assembled short blocks in stock.
Thanks
Dominic
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 11, 2014 | 03:01 PM
ATK Engines's Avatar
We have iron 5.3's in a .030 bore available. You can have a local shop punch it out to the 3.898 bore and use it.
https://ls1tech.com/forums/sponsor-s...re-blocks.html
Old Nov 11, 2014 | 03:36 PM
HCI2000SS's Avatar
TMS block here and couldn't be happier!
