Rear Cover Question
Have you checked for pressure with a mechanical gauge ? Common to brake the OPSU when removing intake manifold. The barbell could be missing as you mentioned. There is also a frost plug in the front of the block behind the timing cover. The machine shop may have removed to clean the oil passage. Here's what I'm talking about.
