ls1 block 5.3 heads?
Old May 25, 2004 | 11:24 PM
dubrado's Avatar
Default ls1 block 5.3 heads?
when doing the ls1 w/5.3 heads, do you use the stock 5.3 valves or are you guys switching those out for the ls1 valves?
just making sure there aren't any piston/valve clearance issues
Old May 25, 2004 | 11:55 PM
Jason99T/A's Avatar
I can shift faster than you.
You really need to, at a bare minimum, open the 5.3l combustion chambers to the LS1's 3.898" bore and install either stock 2.00" intake valves or a 2.02" aftermarket valve. Otherwise, the 5.3l heads would not be of much benefit.
