SES light flashing...HELP!
Old Nov 30, 2014 | 01:19 PM
Lord Vader's Avatar
Default SES light flashing...HELP!
My ses light started blinking today. The light has been on for 1 week but started blinking today. I scanned it and get codes P1133 and P1153 O2 sensor Insufficient switching in both banks on sensor 1. Usually I clear the codes when they pop up but this time I didn't clear it. I have long tube headers and I know it's a common code to throw with long tubes. Is the ses light blinking because I didn't clear the codes and just let them stay on?
Old Nov 30, 2014 | 04:21 PM
M.BOZZ's Avatar
Most of the time when the light starts blinking its a misfire. How do the car run ?
Old Nov 30, 2014 | 04:45 PM
Lord Vader's Avatar
yesterday i put covers over the spark plug wires...after i posted what happened i went outside and checked to make sure the plug wires clicked into the coil packs and spark plugs...driver side was good.....i think it was the second one in from the front on the passenger side. i heard a click when i pushed the spark wire on the coil pack. I took the car out for about a 50 mile ride. NO FLASHING!!!!....i guess the spark wire wasn't set in all the way on the coil pack.
Old Nov 30, 2014 | 04:48 PM
Lord Vader's Avatar
why didn't it throw a DTC for that cylinder tho? the only codes i got where the ones i mentioned.
Old Nov 30, 2014 | 05:22 PM
M.BOZZ's Avatar
Is the tool you have a code puller or a real scanner ? Its possible that the misfire code was under a pending code and not a current code
Old Nov 30, 2014 | 05:33 PM
Lord Vader's Avatar
not sure its a.....Actron PocketScan Plus CP9550
