Need valves for AFR
Old Dec 1, 2014 | 07:01 AM
hilio's Avatar
Default Need valves for AFR
Hi.
I need those valves for my AFR 205 heads:
Intake #7207 and exhaust #7228
Where to buy ?
Old Dec 1, 2014 | 07:36 AM
Tuskyz28's Avatar
Contact AFR directly or Pm Tony Mamo.
Old Dec 1, 2014 | 08:36 PM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Yes sir
OP....if you haven't got sorted out yet shoot me a PM
I will get you handled
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old Dec 2, 2014 | 08:46 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Originally Posted by Tony Mamo
Yes sir OP....if you haven't got sorted out yet shoot me a PM I will get you handled -Tony
Off topic kinda...
Tony, can you cut down LS3 valves for the AFR heads? Just curious. Seemed like an appropriate question given the nature of the thread...
Old Dec 2, 2014 | 08:50 PM
LS1Tech Sponsor
Originally Posted by dr_whigham
Off topic kinda...
Sure.....the lengths should be the same.
Still prefer a beefier hollow stem aftermarket valve.....its a much more rugged design.....better steel etc. although for a good N/A piece, an OEM cut down valve would probably work fine.
-Tony
__________________
