Shift points for a 224/224 - 114????
Old May 26, 2004 | 08:42 PM
IDSTAR2's Avatar
Default Shift points for a 224/224 - 114????
Could someone tell me what the shift points would be on a TR 224/224-114 cam?
Old May 26, 2004 | 08:57 PM
foff667's Avatar
LS1TECH Sponsor
i would assume 6700+
Old May 27, 2004 | 08:16 AM
1fastWS6's Avatar
Dude, you're smokin' crack!
Mine peaks at 6000 rpm. I shift it at 6400.
Old May 27, 2004 | 09:57 AM
foff667's Avatar
LS1TECH Sponsor
i wouldve assumed the 224 on a 114 peaks @ 6400ish meaning a shiftpoint of 6700, guess im wrong
Old May 27, 2004 | 10:32 AM
foff667's Avatar
LS1TECH Sponsor
and fwiw i calculated the SP's for this 224/114 graph https://ls1tech.com/forums/attachmen...achmentid=1761
comes out to 6800 being optimal using http://www.prestage.com/carmath/calc_shiftpoints.asp
so no need to get loud...even with the 6100 rpm peak he should shift @ 6800 if you want to get the most out of it.
Old May 27, 2004 | 11:16 AM
superslowjoe's Avatar
I shift mine at 6600, anything over seemsthe power drops off?
Old May 27, 2004 | 11:47 AM
Bad30th's Avatar
It all depends, my 222/224 114LSA cam peaks at ~7k :
You can install it advanced a few degrees to raise the peak (at the expense of low end). Some cams also have advance ground into them.
Bad30th
Old May 27, 2004 | 12:04 PM
foff667's Avatar
LS1TECH Sponsor
i think your dyno was done unlocked which throws off the #'s by a couple hundred rpm if i remember correctly but yah even if you make peak at 6000 if your basically flatlining till 6300-6400 your not gonna shift till after that anywayz...i shift at 6600 when my cam peaks at 6300 + flatlines till past 6600, but thats where I feel safe having my auto shift.
Old May 27, 2004 | 12:05 PM
Ravenous T\A's Avatar
Mine Peaks at 6100rpm's with my M6, so it just depends where your peak point is, just get it dynoed and see where your at. Check the page for my Mods, im doing 378rwhp & 378tq, dyno was right after install
