et gain's with heads ....
FWIW it's hard to launch a M6 IRS GTO. Clearly, ported heads flow better than stock castings. Therefore, while youre on stock castings, you dont need to run as much durarion and lift, with as aggressive valve events because at a certain point, the heads simply cant keep up and youll get diminishing returns.
Now when you go to ported/aftermarket castings, that limit gets raised by a considerable amount. The velocity and cfm of the head increases, along with efficiency in the combustion chamber among other things. Now, if youre going for max effort, you need to cam more. The cam you had with the stock heads is now not sufficient for the ported heads because the have the ability to flow more. The more air and fuel you can cram into the cylinder, the more power youll make. Now going with a smaller cam with ported heads like you say is a great idea for a street car, but max effort, youre going in the wrong direction.
If you're looking for the ultimate customization for your own needs, then you should look into the many porters out there that do custom hand work on off the shelf heads that deal with certain aspects of those that need more attention. For example, you hear many good things of "Mamofied" heads where he takes an already good AFR casting and puts in a custom hand touch for added benefits wherever the owner needs them. So there's really no excuse for a ported head to be put onto a well setup engine and make the car slower. If you do your homework and buy the right combo a nice set of heads will definitely make your car faster.
