Engine Build - Going Turblowed
Old Dec 9, 2014 | 10:54 PM
JordanRN's Avatar
Default Engine Build - Going Turblowed
Well the day has finally come for me to swap my 243 heads... Passenger side head decided it did not want to live any longer... Dropping the 243's off tomorrow to have them cleaned and a valve job performed.
You can catch your finger nail in the scoring on the cylinder wall, thinking a hone might take care of it? Also concerned about the piston itself.
Any input is great!
Old Dec 10, 2014 | 10:39 AM
SH1ZN1T's Avatar
Old Dec 10, 2014 | 01:39 PM
JordanRN's Avatar
Just ordered new lifters, trays, and head stud kit. Sent the 243's off this afternoon to have them worked over. Hopefully everything arrives in 2 days since they are close and the machine shop finishes in 2 days ( Can't rush this part, I know. ) Fingers crossed.
Old Dec 14, 2014 | 07:01 AM
RezinTexas's Avatar
Originally Posted by JordanRN
This looks like a crack to me.
Old Dec 14, 2014 | 09:27 PM
JordanRN's Avatar
Scored a semi complete 5.3 motor yesterday for $400 and a bottom end 5.3L (with pistons and rods) for $140.
The block and crank will definitely need some loving at the machine shop but the semi complete one should be just fine. It had 110,xxx miles on it when pulled from what the PO said. Guy blew out his transfer case in his silverado and coated the whole engine in gear oil....
The cylinders cleaned up pretty nice after a WD40 bath and rags.
No plans as of yet, but I'm thinking a small cam before I drop her in and boost project in the summer.
Old Dec 16, 2014 | 06:55 PM
JordanRN's Avatar
Got a engine stand and was able to get to the bottom end today, everything looks amazing. Cleaned up a slow head gasket leak in cylinder two. Minimal sludge in the oil pan, previous owner did a great job taking care of this motor.
Old Dec 18, 2014 | 08:12 AM
JordanRN's Avatar
Heads are back from the machine shop. Haven't decided if I want to mill them or not.
Old Dec 18, 2014 | 07:57 PM
JordanRN's Avatar
Had two packages of goodies arrive today!
Old Dec 19, 2014 | 07:47 PM
WEIGHTMAN's Avatar
I 2nd the crack thought, is that piece of metal in the cylinder a helicoil gone wrong,
Old Dec 21, 2014 | 04:03 PM
JordanRN's Avatar
It's not part of the helio coil but is a helio coil gone wrong and nitrous gone wrong. If you look at the head picture, you'll see where the threads broke off and ate the engine to bits.
Old Dec 22, 2014 | 10:30 PM
JordanRN's Avatar
Welllll pulling the old LM7 cam out turned horrible. 2nd to last cam bearing has a nice size hole in it from cam being stuck.
Local machine shop is giving me a hell of a deal to clean everything, new cam bearings and polish the crank so I guess some good things are coming out of it.
Old Dec 23, 2014 | 12:40 AM
JordanRN's Avatar
Appears I have another table to build with this 5.3 motor. Cam bearing actually spun and knarled up the oiling hole.
Off to the other 5.3 block I go....
Old Dec 23, 2014 | 02:12 AM
JordanRN's Avatar
Got the other 5.3 down to bare block. Previous owner let the block sit in a wooden shed without cover or being prepped for storage. Looks a lot better than the other block minus the gunk.
Cam picture below shows cam from block just disassembled and the block with spun cam bearing.
Edit***
I stated above Previous Owner took care of the block, well he can kiss my a**. $400 + 4hour trip + $40 gas mistake.
Old Dec 23, 2014 | 02:53 PM
JordanRN's Avatar
Machine shop doing some excellent work!
Cannot wait to see how the block paint will look.
On a side note, I have a Rollmaster LS2 timing chain, will this work with the 5.3 block?
P/N CS1180
Chev S/Block LS2 Gen3
Sing Row Timing Set
Chain 3SR60-2
Old Dec 23, 2014 | 06:17 PM
RezinTexas's Avatar
yes.....
Old Dec 23, 2014 | 07:05 PM
JordanRN's Avatar
Originally Posted by RezinTexas
yes.....
Thanks for the response!
Old Dec 24, 2014 | 04:37 PM
JordanRN's Avatar
Block and crank back from the machine shop, they did some awesome work..
Cherry Red is the block color and black covers. Car is black and has red calipers with some red bird accents.
Crank was polished.
Florida weather sucks, raining for past three days so little surface rust is forming.
Old Dec 24, 2014 | 05:21 PM
LS1-450's Avatar
Here, let me help.
Old Dec 24, 2014 | 05:29 PM
JordanRN's Avatar
Originally Posted by LS1-450
Here, let me help.
All my local shops are closed till after the new year. -___-
Old Dec 26, 2014 | 12:16 AM
JordanRN's Avatar
Sorry, had to post the obligatory head stud picture.
