Engine Build - Going Turblowed
It made 470/490 on 6#s on 93. With e85 in expecting well over 700 once it's turned up.
Currently experiencing the hurricane here in Florida so I might as well be productive.. Have a guy actually assembling the rear tomorrow.
Ordered some fittings to redo my scavenge pump connections as they're currently barb style, not a fan. Transmission is ready to install, will be installing the rear and trans at same time, wiring up transbrake and repinning harness too.
Prepping her for FL2K16 if anyone else from here is going.
Had to notch bolt holes with BMR crossmember and notch the body too for the plugin. Went with the SpearTech harness instead of repinning it. Transbrake is wired up and functioning properly as well.
I disabled the P0785, P1860, and P1870 codes to let shift... It disabled my RPM display on gauge cluster though.
Couple other items to small tweaks needed and then going to have it tuned.
Side Note: Bought this beauty last year, haha. So I've been having fun in this while finishing the bird.
Will keep thread updated as we progress on.
- Cam Sensor Harness reworked, was causing issues and hard starts
- Fixed Gas Pedal only giving 50-60% when pushed to floor
- Went back to stock alternator location and stock alternator
- Converter is now a billet triple disc with a 2800 stall speed
- Power Steering Lines now AN (CBR Kit)
- New down pipe fabricated
- Bumper finally put back on (5 years of bumperless jokes)
- New tires, ET Street Pros (275-60-15)
- Relocated turn signal to fog lights due to BOV placement
We have a private track rental lined up for the 31st of this month, so finally taking the car there to see what it will do.
FIC 1200CC Injectors
Precision 46mm Wastegate
Two 450LPH Fuel Pumps
Flex Fuel Sensor
New Transcooler
Lots of wiring fixes; fuel pumps, scavenge pumps, fans etc.
Replaced Center Cartridge on Turbo, seals failed.
I'm sure I'm missing stuff, but it's in a drivable state and to the point where it won't have issues after a single trip.
Not sure on power since dyno last Wednesday, but it made over 800ft lbs of torque to wheels. They are still working out the tune to squeeze more power out of it.
Friend said it was one of the more fun cars to drive that's he's worked on.
Desperately needs a Purple Power bath from the years of leaks.
