LS1 Cam selection help
I have LS6 intake, double springs, TSP oil pump, Underdrive pulley, Double roller timing chain, 85mm MAF and arp rod bolts.
You also have to keep in mind that a shelf grinds aren't always necessarily the best grinds, they just might be the most popular. Sometimes they're the same thing but not always. Furthermore, to know the approximate cam you need to first understand what the different cam specs mean and know what deviating from those spec does. This will increase the odds you'll get a cam best suited to your needs/wants, regardless of whether it's a shelf or custom grind. Myself if I see that one (or more) of the sponsors offers a shelf cam very close to what I would spec for a certain application then I'll likely recommend it, but if not I will recommend custom specs I feel are a better choice for that application.
